blsnelling
Friend of the Riff Raff
- 4:26 PM
- Jan 8, 2016
- Franklin, OH
Yes, you want to put sealant on the OD.
Thanks,The 440 has that stupid bushing just like the 372xp....so the coke can trick applies when you are inserting the bushing. Take your time. Don't just shove it in there.
I was actually going to insert the bushing first, then push the seal over that.
I just had a think about how stihl intended the design to pan out, and it seems (to me at least) clear that they intend the bushing to rotate in sync with the crankshaft (??), and therefore it seemed to make sense to have this stupid bush on the shaft first prior to the introduction of the seal. And also, all the oil seal arrangements I've seen in the past have it so that the seal lips are pushing out from the casing. This method of fitting seems to prefer that MO.Less chance of rolling the lip of the seal back or tearing it doing it this way. Those bush edges are sharp, or they are on a 372xp
What I did with my 372xp was put a nice coat of loc n seal on the inside of the bush prior to fitting. I found that the sealant just pushed out when pushing the bush onto the shaft. Then put another small amount around the top of the bush and left it to seep down between bush and crank. Left that overnight to cure then slipped the seal over the top. The way any seal wants to go on. And yes the bush should stay moving with the shaft else there would be serious heat/friction issues.I just had a think about how stihl intended the design to pan out, and it seems (to me at least) clear that they intend the bushing to rotate in sync with the crankshaft (??), and therefore it seemed to make sense to have this stupid bush on the shaft first prior to the introduction of the seal. And also, all the oil seal arrangements I've seen in the past have it so that the seal lips are pushing out from the casing. This method of fitting seems to prefer that MO.
And if anyone think I'm obsessing too much about this, I'll just add "I don't care"
What kind of air leak do you mean, i.e. how long to leak down from 0.5 to 0.3 bar? Say 5 minutes or so?The bushing will rotate with the crank once the clutch is tightened down, installing the seal can be done either way just as successful. Coat the crankshaft with some hard grease before final install of the bushing, helps stop a very slow air leak we all find after assembly on this model.
If done right, the leak is within spec and just barely noticeable with proper clutch torque.What kind of air leak do you mean, i.e. how long to leak down from 0.5 to 0.3 bar? Say 5 minutes or so?
Thanks,
I was actually going to insert the bushing first, then push the seal over that. I did raise the question (i.e. bushing or seal in first) in here http://opeforum.com/threads/044-pto-crank-and-oil-spacer-bush-seal-question.7929/ a while back and mileage seemed to vary as to the "best order". The manual describes both ways, IIRC.
But thanks for the tip my friend, and if I f**k up I'll let you guys know!
And I indeed have found myself such a candidate O ring...... I shall be using the "Junkman" technique.Matt, the early 044s did have an O ring, it has been discussed by Brian (Junkman).
Even w/o the O ring, they do not all leak, but I did change seals on my 044 once (in 25 years).
You can leave the bushing in though and still service the oiler I think though. I can't remember quite how I stripped mine down, but it should be possible, with the clearances etc..Again, thinking of Stihl’s engineering here— why would they require the seal to be removed when servicing the oil pump system and the bushing? My logic is that they didn’t, and that the seal goes in first, then the bushing is slowly worked into the seal lips as described.
Yeah, on the 044 it certainly was better that way.Install that bushing AFTER you install the seal.
10-4 on the press sleeves.......but then again I can f**k something up even with the right tools!I ordered the seal press sleeves for an 026 I recently rebuilt for my boss. If you’ve never used the OEM press sleeves, you don’t know what you’re missing.
