041 open or closed port
jake wells
no longer here
10:48 AM
ky
have not pulled it apart to see but i thought i would ask.
jake wells
no longer here
10:48 AM
ky
i shined a flashlight through the exhaust and intake and think it is a closed port. im going to get a piston kit soon and pull the jug for some mods.
might see how much brett would charge to take 0.40 off the base i still need to measure squish before and after the base gasket delete.
jake wells
no longer here
10:48 AM
ky
thanks jim this saw isn't the super it is just the 44mm set up it has carbon streaking on the piston and blows only 140lbs that is reason im going to pull it apart for some work. get a piston kit and clean up the cylinder.
CrufflerJJ
11:48 AM
Ohioooo
Taking 4/10 of an inch off the base would certainly raise the compression!:eek:
lwhaples
11:48 AM
Vt
Keep us posted. I have an 041 on the pile that may get looked at down the road.
GoBigBlue1984
Bluegrass Fart Knocker...
11:48 AM
Kentucky
Next time your up on a weekend Jake bring the jug with you, we can run up to the shop and get you taken care of big guy.
Chainsaw Jim
Con Artist LLC
8:48 AM
Springfield Oregon
You might disable the flood limiter on the carb and see how it runs if you haven't already done so. The super also has a removable restrictor on the air cover. I'm not sure if other models are the same.
jake wells
no longer here
10:48 AM
ky
This carb doesn't have a limiter I already checked
