- 1:35 AM
- Feb 4, 2017
- Winona County, MN
I’ve seen rails dressed on a table saw with a cut off wheel. Works well.
THAT I can do. (Or at least attempt and possibly mess up.)I’ve seen rails dressed on a table saw with a cut off wheel. Works well.
You have to move it back and forth.I have a rolling rail closer. Never got it to work well.
The rails likely aren't worn evenly.
If you're talking about the place in Portland on Johnson Creek blvd, they're out of business. Bill passed away a while ago.
Bill was a pretty cool, I'm sorry to hear of his passing. I was there before and when he was was in the process of closing. He had said that he had bought some acreage in Mississippi with a catfish pond on it to retire to. I live just over a mile from where is shop was and still drive by it almost daily. Actually he had to have a strong set of lungs as inside his place had a constant haze of grinding wheel and the taste of it was always pretty strong in the air. He had a helper from Wasington that worked there and his Logosol stuff went to a place in Amboy or Yacult. We lost another, last of the guys that did that specialty type of work.Pacific Trail Manufacturing is still around - they do bar repairs and custom bars, they're in Portland.
I stopped in at Chainbar Repair a couple times in the late 90's/early 2000's and chatted with Bill quite a bit. He was a great old boy. I think he was in his late 70's when he passed.
Smart people run .058 for this very reason, when it wears you can throw an .063 on, double the life and halve the costChainsaw bars are consumables same as chains.
I have worn out dozens of chains, but only one AM bar.
I run the factory original Dolmar branded Oregon laminate bar on my 2006. purchased Dolmar PS-6400 and she is my main go to workhorse.
I did deepen the groove at the bars tail section twice.
It is a .058" gauge bar, I can run a .063" chain in it.
I made my own bar grinder, I machined an aluminium disk and put stick on sandpaper on it. I then found a 1hp electric motor and made a frame and table with the disk at 90deg to the table. Works for me.
That'd make a magnet fishing person happy!buy a new bar throw that one in the river
Entirely possible.Shows no signs of wear…I almost wonder if it wasn’t originally .063” and mislabeled or something.
