036 stalls when tipped down at idle
cuttinsquirrel
Active OPE Member
12:07 PM
Vermont
I have an 036 with a new cyl and pistons andboth seals have been replaced. When the saw is ideling and the nose of the bar is lowerd it will stall.
Does anyone have any ideas.
Thanks,cuttin squirrel
Mark71gtx
12:07 PM
Fuquay Varina, NC
Dis you do a vacuum/pressure test? Could be a pinhole in the fuel line. When the portion with the pinhole is no longer covered in fuel, it becomes an air leak.
czar800
12:07 PM
Ellwood City
I would try adjusting the carb. Did you rebuild the carb? If not now might be a good time.
Mark71gtx
12:07 PM
Fuquay Varina, NC
If you need to replace the fuel line, or already have, buy a new line from Stihl. Aftermarket fuel lines for Stihl saws suck. I have had to replace every one I have ever installed because they pinch and block the flow of fuel. Now when someone brings me the aftermarket fuel lines to install, I hand them right back to them...
12:07 PM
replace fuel line with oem the aftermarket ones last about a year
