Wt 215 swap
94BULLITT
2:31 AM
VA
I had to plug a hole in the air box. I think it was from the intelli carb.
Hinerman
1:31 AM
NE OK
Good pics Jer
Did you have to switch the top plates on the carbs? WT 215 is the carb in front. Do I switch the top plates, or whatever they are called? I saw somebody switch them online somewhere…
cus_deluxe
terms of service violator
2:31 AM
Michigan
yeah if you need the compensating thingy and the holes line up you can just swap the covers.
Evansaw
9:31 AM
Greece
Sorry to jump in as I never did anything like this, but read somewhere that also the ms231 carb can fit
president
11:31 PM
peachland BC Canada
You need to use the correct impulse passage, both are present on the carb. Just look at the intake. Pull the brass plug out of the correct hole and put a dab of epoxy in the unused one. The throttle linkage needs a little finagling to get full throttle. That should be it.
Adirondackstihl
2:31 AM
Upstate NY
I just use Yamabond or Dirko for the sealant.
Just a dab is all you need.
