Worst case of mag rot ever.
Wood Doctor
Edwin
12:17 AM
Omaha, Nebraska
That's enough to make me start storing all my saws on short pegs or a pair of 1 x 1 hardwood slats. Gasp!
av8or3
1:17 AM
Waleska,Ga.
Doesn’t palm sap do that if not rinsed?
I think it does, but I’ve only read and seen pictures of it. I have personal experience with the concrete damage.
hardhat
12:17 AM
Lucedale, MS
Crap. I’ve had mine sitting on concrete for years. Maybe the protective layer of sawdust and oil have prevented this. I absolutely get it though and will put down some rubber matting where they sit.
Yukon Stihl
10:17 PM
Great White North
Do you live in a Humid area? Close to a body of water?
I't's dry here and there are no issues of saws on concrete.
Just wondering on what conditions would cause that.
av8or3
1:17 AM
Waleska,Ga.
There is a thread on exactly that floating around here. I was thinking about it this morning. I’ve always kept my saws up off the ground. When I lived in Central Florida the bottom edges of my rider mower deck started to get fuzzy and in places actually split from the corrosion. It wasn’t even touching the floor. It was kept inside the garage. I have left a busted Husqvarna 372 crank case laying on my concrete garage floor now for two years and it’s not corroding. ??? Now I live in N. Georgia. While I have my own ideas about what’s going on, I don’t know for sure.
1:17 AM
It's a chemical reaction caused by one component of Portland cement .The blue clay slurry contains alumina a couple of valance electrons away from aluminum that causes it, the concrete eating away at anything with aluminum in it .Chainsaws are not the only thing that can get gobbled up because over time it can get window cases , screen doors etc .Stihl for one used E coat to try to prevent this which from my observation has worked .The older saws such as my avatar saw ,a 2100S Homelite do get messed up .Fact on that one I had to repair the front of the oil tank with JB Weld .
heimannm
12:17 AM
Dike, Iowa
I've seen worse...and this was mostly aluminum not magnesium.
Mark
1:17 AM
Aluminum ,mag and zink are known as "sacrificing " metals .Not only does the reaction with concrete eat it up but also dissimilar metals plays a big part in it .Cathodic protection such what is used on pipe lines ,under ground storage tanks etc is a study and a science all it's own .It finds it's way into simple things like small engines . I'll just mention it but not go into detail because it could over load the server .
