dustinwilt68
Wilt Built Work Saws
- 1:11 PM
- Mar 8, 2016
- Southwest PA
If stihl guys would just run husqvarna mix 40:1 they would have less failures. Just my 2 cents.
What do you do to the carb on these Scott?I finished up on a 661 and moved on to the 200t.
rope is broke, air filter is getting thin, fuel line cracking but not leaking.
started a list of needed parts.
cleaned the saw up , looks good.
advanced the timing, carb mod, muffler mod, is all I do to these and is now done.
By a sharp chain I mean the cutter is sharp and the rakers are set correctly, not the burnt tooth with rakers ground off that seems popular around here.
Still 32:1 after all these years....and boy do I get Chit for it from the experts.
By "around here" I meant locally, not here as in the population of the forum. Sorry for the confusion.I must have missed this. Do you have a link?
I'm here nowI'd like to thank everybody for staying on topic on in this thread. It's certainly easier to keep track of what Scott is showing now that the thread isn't being clogged up with a bunch of posts that have nothing to do with the saws Scott's talking about.
Kudos to you.
nothing against husky oil i used it for years 40/1 but i have had a couple of saws brought in with stuck rings no other damage but i couldn't tell you what the mix ratio was anyone else have any problem with it.And how would you explain this dot dot dot .View attachment 62600
Some burns in the top end. It all doesn't stay in the bottom.I run 32:1, just to be clear.
I get the argument that oil burns hotter than gas, so more oil means more heat and that is a bad thing??
My understanding is the oil drops out of the fuel mixture and does not all burn. Not trying to derail, how do you answer that argument??
Scott, just a little tip I picked up from a build thread on here. If you pull the cylinder off of the saw it's easier to see into the cylinder. Feel free to use that in your own shop in the future.
@tree monkey thank you for the thread, even tho its turned into a pissing match by others
Meh... Just need a "weed out the dicks program". I could clean this place out in about 20 minutes.
WTF is going on in here?
Who ya wanna cull?
I got my ban hammer.
Brad is building a 346....and minding his own business. He sent me pics.
I don't measure intake either. I just eye it and stay within my skirt
I'd love to wash dirty saws and sweep chips off the floor in a few of you guys shops.
A couple questions come to mind.
Have you checked the squish? Any chance there could be a bottom end bearing issue at play here, allowing the piston to over-travel?
Was this cylinder new to this saw? How would the plating get worn through in such quick order?
What's the weakest link in the chainsaw system?
aren't you the guy that told me that taking the cylinder off was a waste of time?
don't ya just hate it when grandma wins.
but ya might end up all alone.
wtf, ya done scared everyone away.
nude selfies?
how long have you been wearing a skirt?
I haven't cleaned the shop in about 5 years, your welcome here anytime.
what do I use to check squish when it is zero?
this was a new saw.
the piston is trying to clime through the port.
the starter handle. cut it off, no more problems.
