Will a 351 piston work on a 353 cylinder?
Adamski
Plebus Splederns
9:56 PM
Essex, UK
I have a 353 coming to me with suspect scoring. I have a decent genuine 351 piston kit. Will it work? While I'm there I was going to clean up and port the transfers and open out the exhaust port and muffler a tad. Anything else to do? If I remember correctly the timing can be advanced. I'm not after anything major, just little gains here and there.
Thanks in advance guys [emoji106]
Sent from my Pixel 5 using Tapatalk
Wood Doctor
Edwin
3:56 PM
Omaha, Nebraska
My rule of thumb. Always buy the piston, rings, and the cylinder together as a P/C kit and replace them both at the same time. That works for me.
Woodrow
Reynolds Crane - Home of Ported and Polished Saws
3:56 PM
Wisconsin
The Duke at sawsalvage.com has nice aftermarket pistons for the 353 for $21.00. Pretty hard to beat and much better quality than Highway.
Orangeinthebarn
4:56 PM
Tennessee
Do a base gasket delete and muffler mod. Not sure about a 353 but if you put a 346ne cylinder on it bgd will be close to .020. Sometimes you can find 346ne p/c kits for $100 and it’s well worth it.
Adamski
Plebus Splederns
9:56 PM
Essex, UK
Thanks guys.
Over here in the UK it's impossible to find anything 346xp that is decent or original or cheap. A kit is nearly £200.
I have the 351 cylinder and piston, original and in good condition. I have a 545 MK2 and 550xp mk2. I just wanted something a tad lighter for in a tree when the 200t runs out of puff. I'll do some muffler, gasket, port and timing work on the 351 top end and see what I can get out of it with a 15" bar.
Kiwioilboiler
346 Pic Examiner
8:56 AM
Marsden Pt, NZ
Thanks guys.
View attachment 339944View attachment 339945
That an interesting looking 351 mate.
Clutch side handle overlay I've not seen before.
And the clutch cover is off a later one too.
Tag defo days 351?
Another Adam.
3:56 PM
Tag defo days 351?
Another Adam.
They continued to sell and update a lot of saws in the UK and in Asia that were nixed in our countries. That could explain the differences.
Adamski
Plebus Splederns
9:56 PM
Essex, UK
Tag defo days 351?
Another Adam.
Nope. It's a 346xpg. Has a 353 cylinder on it and a 346xp clutch cover. It's all genuine and a few new parts like the muffler. But the piston is scored to hell. The recoil is off an older 346xp.
But.. I have a 351 piston kit sitting in a box to go on it, unless I can find a 346xp kit somehow.
There you go, a bit of everything on this one.
Nice hearing from you, from another Adam [emoji106]
Kiwioilboiler
346 Pic Examiner
8:56 AM
Marsden Pt, NZ
Sorry bro, should have reread from top.
Can't just get a 353 Meteor piston in the UK?
I built one with a HyWay popup, but wouldn't bother again. Circlips, rings all dicey, too much trouble after changing over to OEM and caber. Ran like the wind, but ended up too spendy.
Adamski
Plebus Splederns
9:56 PM
Essex, UK
I literally can't find a meteor, hyway etc 353 here. The genuine ones are £100 ish. I can't warrant that atm.
I'll figure something out [emoji3526]
Int1968
3:56 PM
Ontario, Canada
Tag defo days 351?
Another Adam.
Is it a g model? In Canada the 353 was available with heated handles, only seen a few, 351 is uncommon around here.
Adamski
Plebus Splederns
9:56 PM
Essex, UK
So I have thrown it all back together, 351 Mahle cylinder, 346xpg case handles and the likes. I have opened up the muffler and deleted the cylinder gasket. It's nice for what it is.
