Why use the 199 on a 346xp?
shorthunter
11:01 PM
West Central Missouri
I have a 346 here with the 154 carb. It seems that everyone wants a 199 carb on their 346, my question is why?
The 154 has a 15.08 mm venturi, the 199 has a 16.66 mm venturi. Why not just thin the shafts on the 154 to get the extra flow
SquareFile
12:01 AM
somewhere
For bragging rights, even though most don't test before and after. IMO
Cut4fun
Redneck Chainsaw Repair
12:01 AM
Ohio
I had a dozerdan OE 346 with 199 carb. In cookie cutting it was 10% faster with 357 carb then with 346 carb.
In the real world cutting firewood etc it dont mean squat IMO. The wood will never know the difference in the times.
I have the cut times saved from my testing. I will dig it up.
Also 199 191 175 (might be a few more that is the same) carbs can be used if you feel the need. Not really needed unless cutting for times.
Have seen even bigger carbs on 346. Thinking a HL, 066 carb. Seen 084 on a 026. Heck had a 272 on my 5000.
11:01 PM
I don't see any real differences in the saws I build. That might be because of the way I build them.......I'm not sure.
Like Shawn said........most guys wanna be able to say they've done all they can. Bragging rights.
sunfish
11:01 PM
Success Mo
I feel the difference, but it's small. There will likely be no gains on a stock saw though.
Cut4fun
12:01 AM
Ohio
Never even heard of someone doing it to a stock saw. I wouldnt even consider that.
Reason I say that on a stock 6700. I took a 6700 carb off put on a bigger 8000 carb on a stock saw. It felt stronger by the seat of the pants. But was it, I dont know. I pulled the carb off put the 6700 carb back on and the wood couldnt tell the difference. :risas3:
