sonoransaw
- 4:53 PM
- Jan 7, 2020
- Arizona
Hey, it's all about "hacks" these days.....if it works, that's what counts....Thanks!
I'll see about getting more pics/info off the chain after work...If they're selling a new saw with some substitute chain, that would kinda suck....
As noted, those are low kickback drive link bumpers (there are different styles), which are generally considered an improvement over low kickback tie strap bumpers (again, there are some different styles). The low kickback tie strap bumper style chains are an older design, but will cut smoother on smaller diameter limbs, and are preferred for some application, like pole saws.Why do these chains have double rakers side by side?
Again, don't get all caught up in every different way to do things until you have mastered basic sharpening. We discussed using a constant offset depth gauge tool versus a progressive depth gauge tool in another thread. These work fine for tens of millions of chainsaw users. If the chain does not cut as aggressively as you want *after half of it's life has been used up*, take an additional pass or 2 with the file on each depth gauge. But the cutting edges have to be sharp first.Could you guys post a pic of what depth gauge you would use with these chains? Thanks!
Sorry that it took him all night to switch chains.He was having trouble with his chain/bar overheating and he switched over to a standard single raker and it was night and day.
I can round file it for you. I do not use depth gauges. I go by feel. And chip size.
