why 359/357 xp ?
angelo c
Coal Member
10:48 AM
Guys, picked up a blowed up 359 and am planning on "someday building" it...
question for the Husky guys is why would you 357 a 359 saw or would you convert it at all ?
what are the differences ? other then the XP in the 357 ?
not planning on porting it at this point so....
Onan18
OPE Sponsor
10:48 AM
Georgia
The 357 XP had crank stuffers, the 359 did not. Also the 357 is a Quad port bottom fed transfers like a 372 or 346, 359 is sort of a "in between" cylinder design. Some guys say unless you are going to add stuffers stick with the 359 top end but I put a 357 top end on a 359 this past spring and it ran really well.
Wagnerwerks
10:48 AM
Pa
I have piles of both... I still think the 359 bottom with the 357 top has the best torque and works the best for firewood. I just built a ported 359 and it runs well but my old 357 was a bit better. We'll see when this one breaks in.
I should add. A 359 is easy to clean up the ports and make run very well.
angelo c
Coal Member
10:48 AM
Any differences in bearings or crank ?
Most of the quads I've run seemed to be better on fuel
Case volume affecting torque maybe( no stuffers on 359) ?
angelo c
Coal Member
10:48 AM
Is the swap "plug and play" or is it parts chase?
Wagnerwerks
10:48 AM
Pa
Neil murphy told me the case volume was the factor long ago.
Everything else is identical. You can add stuffers to the 359. Plug and play on everything.... I can get you a deal on a 357 top end new... No more used here...
Onan18
OPE Sponsor
10:48 AM
Georgia
Plug and play for the cylinder swap, not sure if stuffers will fit on a 359 crank without machining, never tried. Cranks will swap though.
jacob j.
Lord of Cargo Pants
7:48 AM
Coastal Oregon
I'll second what the guys above have said- a 359 with stuffers runs good and a 357 without stuffers is a good saw. When the series first came out, I built one of each for myself and then built several of each for a local tree service company. If you're going to do the stuffers in a 359 though, the jug needs quite a bit of work to make a really good runner, whereas the 357 jug doesn't need much when you take the stuffers out.
Ktoom
10:48 AM
Albany, NY
Might it be safe to say that the 357 with stuffers is a better package for limbing with some bucking?
Ive got a 357xp inroute to me and i have a project 2159. I was going to do the 357xp topend on the 2159. Then see which version I like better.... with stuffers or without lol. I owned a 359 almost 15 years ago. Seemed like a great saw, but i knew very little about saws back then. My dad bought it from Lowes as a reconditioned saw for like $300 lol.
Landmark
Chainsaw Hack
10:48 AM
WNC
I have never owned a 359 but i believe I remember @Mastermind said a ported 359 was one of most impressive saws he ever ran. If you didn't say that then please correct me Randy.
Chief Cat Herder
9:48 AM
I think what I really meant (and think I said) was that the 359 gained more from porting than any 60cc saw I'd ever done.
But......they are very impressive.
cgraham1
7:48 AM
Nor Cal
Seems to me like a 357's power is more 'peaky' where as the 359 has a wider powerband, so it's more user friendly for someone less experienced with running saws. Kinda like comparing an MS440 to a Dolmar 7900... the Dolmar is faster, but you have to use more finesse, whereas any monkey can run a 440. Same with 357 vs. 359, or 346 vs. 353. Or VW vs. Porsche. :)
That's just my opinion and I'm not sure if will make any sense to anyone else?o_O
Chief Cat Herder
9:48 AM
Makes sense to me Clint.
Same with the 545 vs the 550.
angelo c
Coal Member
10:48 AM
Is it symptomatic of the suffers or the quad ports ..... Or both ?
Wagnerwerks
10:48 AM
Pa
Have you seen the 359 top out yet? Its pretty clear why its not as great...
I can take some pics of both if you like.
