scooterbum
OPE Member
- 2:59 PM
- Jul 29, 2023
- Michigan, USA
Which hone do I need for a Ryobi weedeater cyl, aluminum oxide or silicon carbide?
Is the cylinder an open port?Which hone do I need for a Ryobi weedeater cyl, aluminum oxide or silicon carbide?
I figured so. I would definitely pass on a hone as it will want to drop into the ports.I guess so. 2stroke with cyl wall ports.
I would make a split mandrel with a bolt or large nail and use it with a drill and sandpaper to remove any transfer. You definitely need to get rid of any high spots. Here is a @Mastermind vid for reference:Then I just re-ring without honing?
Nice pics of the damage! Yeah, I never run a hone in a 2-stroke cylinder....just figured it would be really bad in an open port version.In my experience, it doesn't matter. This was an OE 372 jug that someone had ran a hone in. I'd just stick to the tried and true sandpaper method. Some even go as far as sanding by hand. I don't have that sort of time.View attachment 385735View attachment 385736View attachment 385737
Yes, I am a Powerplant Engineer 1st class, motorcycle mechanic, refrig tech, and heavy metals wastewater treatment plant operator.I've read both threads about your weedeater. You didn't say "why" you think the cylinder needs to be honed. It would seem that you have knowledge of auto or tractor engines that need honing to break the glaze. Plated cylinders are not the same and neither are their methods. I think more information is needed here.
I click on it, nothing happens. It's a black screen.Did you watch Mastermind's video posted above? Ditch the hone
do a youtube search for "removing aluminum transfer without acid"I click on it, nothing happens. It's a black screen.
I went there, page not available.do a youtube search for "removing aluminum transfer without acid"
Not all cylinders are even eligible to hone as the stones will catch, if they are okay, the hone stones need to be of a fine grit spring loaded type at least two inches long and a light lubricant such as WD-40 applied liberally prior to a brief in and out several times while spinning and that's it, no more. Then there are the ball type deglazing hones that need be bought per size of the cylinder diameter, that can be used in the same manner.Yes, I am a Powerplant Engineer 1st class, motorcycle mechanic, refrig tech, and heavy metals wastewater treatment plant operator.
Reason to hone is for light cyl cleanup and ring seating . Caber rings.
So, back on subject, why would an alum oxide hone, run for perhaps 10-20 seconds ruin a cylinder, but grinding on ports doesn't harm the plating?
Some might run an aggressive grit material, and run it too long of duration.
I'm all ears on this subject, because I have 2 or more cyls to do.
Thank you much.
