What would make this seal tear? (036)
BuckthornBonnie
11:07 AM
Penn Yan, NY
Leaving us with the crank--- you can see the step Al mentioned. If it's clean, it probably couldn't do anything.
BuckthornBonnie
11:07 AM
Penn Yan, NY
I suppose the seal could have popped out into the path of the washer, but that crank step is a positive stop. Wrong washer? Clutch drum retainer used instead? Again, probably not.
I think it's a fluke as mentioned above. Cool failure and nice to have video evidence--- reinforces the importance of listening to saws when you're cutting. "The tune don't lie" to paraphrase Rasheed Wallace.
11:07 AM
Thanks for all the pics. Very infomative.
It's possible the seal was put in slightly cockeyed. Not sure if that would do it.
I used a socket and not an oem tool.
It was symmetrically placed. It's possible I dented the edge in a bit.
I really have no idea, but like it was mentioned above, I'm glad it went out before I sent the saw out. Pretty happy I made as many cuts as I did. I knew it was all brand new and wanted to be sure it would hold up. The piston survived just fine. It takes a lot more cutting than one would think to score a piston.
BuckthornBonnie
11:07 AM
Penn Yan, NY
I rarely use any type of sealant. Once in a while I will on a mag case that is a little corroded.
I haven't seen a factory seal with anything but I always put a tiny amount of 518 on the edges. My logic (probably flawed): install and then removal of the original seal could have removed just enough material to leak a bit. The sealant should seal that. 518 is better imo because of it's ability to flush out and only anaerobically cure.
Probably overkill and not needed, tho.
BuckthornBonnie
11:07 AM
Penn Yan, NY
Where the outer circumference meets the case.
Lakeside? or another venerable AS poster once claimed some seals could leak a tiny bit and then not. I think someone even referenced oil/grease/dust buildup as how the tiny leak stops. Sealant seems like good insurance but who knows.
11:07 AM
I've only had one that blew the seal .It was an 038 Mag I had rebuilt three times that had served over twenty years in hard service as a tree service saw .That one I used red loctite .BTW I own that saw now and it probably runs as good today as it did in the 80's when it was new .Tough old saw.
