SELLING What should I pay attention to when using the grinding wheel in life?
Alisajune Thomas
New OPE Member
8:45 PM
China
In recent years, many mechanical products need to be cut by the fast working grinding wheel. The grinding wheel cutting piece is widely used in the current production. The installation of the grinding wheel cutting piece is directly related to the safety problem in the production process. The following Henan abrasive grinding tool elaborates the grinding wheel. What should I pay attention to when using the film in life? Let's take a look at this aspect and learn together.
The spark generated when the fast working grinding wheel is working is very large, so it must be noted that it is burnt. Generally, the following matters should be noted when working on the grinding wheel:
1. Can not be placed around flammable and explosive materials;
2. Do not wear polyester clothing, polyester is a by-product of petroleum, is flammable;
3. Do not wear short sleeves, but should wear long trousers.
The fast working grinding wheel is not rubbed to produce high temperature to burn the contact part, but to generate a sharp angle when rubbing, thereby cutting the hard metal material. Those sparks are only the phenomenon after the angle of interest, not the high temperature generated by friction. Melting the workpiece. The above is the abrasive material of Henan. Explain the relevant content of the grinding wheel in life. We, Henan Aurora Abrasive Tool Co., Ltd. specializes in the fast working grinding wheel and grinding discs. Welcome to the website for advice if you are interested.
redlight066
8:45 AM
Taylors SC
Never go commando while using a grinding wheel.
You always want to keep the old beanbag snug in such a situation.
Lots of talk of rubbing, grinding and so forth.
Is this the new industrial porn thread?
Im still laughing while I'm typing. That sir, is funny
