Pintail120 Well-Known OPE Member Local time 8:30 AM User ID 7203 Joined Sep 3, 2018 Messages 29 Reaction score 36 Location United Kingdom May 20, 2021 #1 Hi, when I stripped the chainsaw down this bearing was dry. Can you please advise if I should put some lubrication on it when I rebuild ? thanks Gavin Attachments Clutch bell.jpeg 57.7 KB · Views: 23
Wonkydonkey Plastic member Local time 8:30 AM User ID 3189 Joined May 14, 2017 Messages 5,572 Reaction score 26,294 Location Sussex, UK. May 20, 2021 #2 I use LM, it’s lithium grease I believe. that bearing only spins on tickover, but it’s a bearing that gets over looked. I try to do mine regularly.
Pintail120 Well-Known OPE Member Local time 8:30 AM User ID 7203 Joined Sep 3, 2018 Messages 29 Reaction score 36 Location United Kingdom May 20, 2021 #3 thank for that helpful info, I live in east sussex(I see your info says sussex) Wonkydonkey said: I use LM, it’s lithium grease I believe. that bearing only spins on tickover, but it’s a bearing that gets over looked. I try to do mine regularly. Click to expand...
Wonkydonkey Plastic member Local time 8:30 AM User ID 3189 Joined May 14, 2017 Messages 5,572 Reaction score 26,294 Location Sussex, UK. May 20, 2021 #4 I'm in Brighton by the racecourse edit, I see your avatar, I used to fly paragliders for a long time, I tried the p-motor but we have hills So I never got into it
OldJack Super OPE Member Local time 1:30 AM User ID 609 Joined Jan 19, 2016 Messages 171 Reaction score 427 Location Saskatchewan, Canada Jun 7, 2021 #5 Steve's Small Engine Saloon shows how to lube a Husqvarna bearing the quick way. It may not work on all models.
