What is s this on carb
DELETED (Struggle)
3:35 AM
iowa
Is this some type of governed deal? If so best way to disable? WS10 carb on partner S55
The tune seems way off ether to rich or lean so I suspect this
DND 9000
9:35 AM
Germany
That`s the speed governor. If it is malfunction the spring inside opens the ball and hole at a to low speed it will flood the engine. The suggestion in the post above will fix that problem.
DELETED (Struggle)
3:35 AM
iowa
Perfect I cut just piece of gorilla tape and put the it over the end. I'll do the gasket as a permanent solution. I do have a leather hole puncher. Great idea! Thanks guys
