What compression testor for saws with 10 mmm plug are you guys using?
Manofstihl661
12:45 AM
Texas
I ordered mine from snap on. There are different valves I believe for automotive, bicycles, all kinds of crud. Something about the resistance in the valves for different applications
Lone Wolf
12:45 AM
Nj
Well Ill call them and get a few.
SteveSr
12:45 AM
North Carolina
Hello,
I know that this is an old thread but as you have shown empirically:
1. Adapter/hose volume matters! Anything in the adapter in front of the Schrader valve that either increases (usually) or decreases the effective size of the compression chamber will affect the compression reading. Obviously the smaller the displacement of the cylinder the more pronounced the effect will be. This is why most of these gauges work alright for large displacement car engines but not so much on smaller saws and brushcutters.
2. The physics behind different Schrader valves is as follows: To get cylinder pressure into the gauge you must provide enough pressure to overcome the spring in the Schrader valve PLUS the pressure already in the gauge on the other side of the Schrader valve. Therefore if it takes 25 pounds to open the Schrader the gauge will read 25 pounds low! You can demonstrate this with an air compressor and suitable regulator just don't connect the gauge. Increase the regulator pressure until the valve opens and you'll have your answer.
Class Assignment -
If you have a suitable air compressor and regulator take a moment to go perform what we'll now call the Schrader valve pop-off test and report the results back here. Inquiring minds want to know which Schraders are the best for this application!
Thanks,
Steve
a. palmer jr.
12:45 AM
Southern Indiana
I just use an el cheapo gauge...I'm not interested in exactly how much compression just need to know if it's adequate. I don't use an adapter.
SteveSr
12:45 AM
North Carolina
Yes, but it will be interesting to find out how much the readings are affected by the various Schrader valves that are in common use.
