What bar mount is this?
67L36Driver
7:03 AM
Remy bars are generally the Homelite (3/8" studs) mount. 3/8" OD X .030" extension spring @ 5-6 coils make 'em fit McCulloch, Echo and Poulan.
idiotwithasaw
7:03 AM
Ky
What's this s clip or extention spring yall talk about?
Mycamaro_68
By guess and by golly
7:03 AM
Cedar Rapids, IA
The slot in the bar is 3/8" wide. The "S" clip slides over 8mm or 5/16" studs (like D176 mount) so the bar can fit on a lot more chainsaws. You can cut a strip of shim stock and make your own. I haven't measured one before but it should be around .030" thick material.
Black Dog Chainsaw
Mak-Crazy
8:03 AM
Indianola, IA
there's also spring/coils that you can slip over the bar stud to make it bigger. I think Modified Mark gave me a couple back when that adjust a bar from 8mm to 9.2mm or maybe it was 9.2mm to 10mm???
Pic of a homemade set...
154361d1398273762-spacer-springs-allow-you-mount-stihl-bars-husqvarna-chainsaws-p1060065.jpg
