What bar mount is this?
idiotwithasaw
11:08 AM
Ky
Got this bar from a farmer friend, he knows I like saws and such. If pretty rough, but I was able to get the sprocket freed up with little effort. just a logger grease in the holes and a light tap with a chisel. Thing is i have no idea what it goes on, looks like maybe a mcculloch or a homelite. Will it work on a husqvarna?20160620_095732.jpg 20160620_095738.jpg
dougand3
11:08 AM
North Alabama
It has a D176 mount look to it. Lots of McCullochs take those. Check stud slot width. D176 = 8.0mm.
Mycamaro_68
By guess and by golly
11:08 AM
Cedar Rapids, IA
D176 usually oils through the adjuster holes. Looks like a D196 home lite mount to me. How wide is the stud slot?
rjames
The clean beaver gets the wood
12:08 PM
Michigan
@Jon1212
My guess is homelite mount also, but Jon will know for sure.
Jon1212
Birch! Please.....
10:08 AM
Utah, unfortunately.....
It appears to be a D196 type mount as Ryan, and Rodney alluded to. It should have a 9.5mm stud slot, which will help verify the mount pattern. With the use of an S clip, or the spring spacers, it can also be utilized on a D176 based saw.
As saws modernized, and many different manufacturers used the D176 and D196 mounts, oil passages were/ are located in both the adjuster pin are, as well as the upper bar rail area.
Jon1212
Birch! Please.....
10:08 AM
As to whether it could be run on a Husqvarna?.........Yes, on a large mount, but it may be a little wobbly in the mounting process.
Mycamaro_68
11:08 AM
Cedar Rapids, IA
I have made my own "S" clip out of some shim stock to make a D196 fit a large mount husky. If I remember right I used a .010" shim.
Black Dog Chainsaw
Mak-Crazy
12:08 PM
Indianola, IA
Don't forget it will run on the bigger ol' Poulans/Pioneers too. 655bp/p60/61/52/50 etc etc etc
Jon1212
Birch! Please.....
10:08 AM
Homelite & Lombard mount right Uncle Jon?
Si señor, plus the larger Poulans, Poulan Pro's(Partner based too), older Echo's (900, 1001), etc.
They are also easy enough to open up a wee bit for use in place of a D024, and use on larger Olympyk's, and older Jonsereds.
idiotwithasaw
11:08 AM
Ky
What would a remington roller nose bar fit on. I have a 25" bar that would be neat to fit on something.
idiotwithasaw
11:08 AM
Ky
That's the exact saw I have with the bar. It's a 754 super
