Weld on to make a Axearoon
OnlyStihl
9:41 PM
PNW
I have a hookaroon/pickaroon, but would like to weld on a 3 to 4 inch point on the back of my axe. Axearoon?
I have plenty of mild steel blanks and I can make the point with. It would be a lot of work though.
Will the mild steel weld up to the back flat end of my old trusty axe?
I'll put a bead on my axe later to day, but just wondering if anybody has attempted this modification to an old axe.
OnlyStihl
9:41 PM
PNW
I didn't weld to an old axe head, but I did make my own hookaroon with 1/4"x2" flat stock and a sharpened Gr5 bolt:
FWIW.
That's the idea. I had to work on a neighbors mower today, will attempt to do some welding on an old hatchet tomorrow.
  • Like
Reactions: Lnk
5:41 AM
Usually ax head steel is rather mild.
The blade gets its hardness through smithing and quenching but the eye stays soft.
I think welding on another piece of steel to the back of the head won't be a problem.
Boomer2230
12:41 AM
Canada
just give it a good cleaning with a grinder to get the hard steel off the head before welding.
Pre heat the steel before welding and let cool slow. Don't quench it.
IffykidMn
10:41 PM
Minnesota
Take a double bit with a damaged bit and turn that side into an axeroon that way you have a reversible handle.
I tried a double bit turned axeroon about 30-40yrs ago and found it heavy to flick around like a pickaroon.
I tried welding a piece of 2X3 1/4" flat steel on a pickaroon to a make chopping edge and found it to light to be of much use for chopping along with the curved handle being the wrong sweep for chopping.
Both were used in a cut and bunch logging operation with pulpwood production in mind.
YMMV good luck.
OnlyStihl
9:41 PM
PNW
Running a weld bead on the axe is good. I've just about figured out how I want the hook and the strengthening braces to look and how to make them.
damifino
10:41 PM
NW Indiana
I like the way you think! Give it a try and if you don't like it cut/grind it off and you have your axe back.
OnlyStihl
9:41 PM
PNW
Not pretty but done. No pictures -- too ugly.
I usually weld with 6013, but those rods are getting used up, so decided to use some 3/32 6011. Easy to start an arc, but burned fast. Holding a consistent arc length and adjusting my travel speed was a challenge (6011), so the weld is lumpy.
Also welding some small triangle pieces to give it all more strength complicated the nice welds I aim for. Oh, well. I'll see how it all works out next time I go firewood cutting, if the heat ever abates. Bloody hot out, all this week.
