Wedge Profiles and Names
How Do You Define These Wedges?
  • 'A' is single taper; 'B' is double taper; 'C' is ?
    Votes: 0 0.0%
  • 'B' is single taper; 'C' is double taper: 'A' is ?
    Votes: 0 0.0%
  • Something else (please describe in a thread comment)
    Votes: 2 100.0%
  • Total voters
    2
Philbert
Chainsaw Enthusiast
3:22 PM
East Dakota
I have heard different definitions for 'single taper wedge' and 'double taper wedge', along with 'single lift' and 'double lift' felling wedges.
To add to the confusion, 'Double Taper' is the brand name for a line of plastic wedges, so ALL of their wedges are 'Double Taper wedges'!
Which wedges in the illustration below do you call 'single taper' and which do you call 'double taper'? I am assuming that wedge 'D' would be a 'triple taper' or 'double lift' for felling?
Philbert
Skeans1
1:22 PM
Philbert
D is the only one there that’s a double taper all the rest in your drawing are singles.
deye223
AIR FUEL SPARK VROOOOOM
6:22 AM
You don't have a single taper profile wedge in that picture hard to explain but if it was left sitting on a flat surface the head of the wedge would be 90 degrees with a single taper running down to the point that way when you stack one on top of the other the overall taper is not too fat at the head for want of a better term makes it easier to drive them in without bouncing out .
deye223
6:22 AM
Please Forgive my crap artwork but this is what I was trying to explain
This is a double taper wedge has nothing to do with the tip or the extra lift at the rear of the wedge .
Philbert
Chainsaw Enthusiast
3:22 PM
East Dakota
In high school, we would call the one in your top sketch a 'right triangle' (90° corner), and the one in your bottom sketch an 'isosceles triangle' (2 of the sides are the same length).
But, as I understand your key point, if I stack 2 wedges 'A' or 2 wedges 'B' back-to-back, even if they formed a single point where they enter the saw kerf, the back of the wedges would meet at an angle, instead of as a single, flat surface to drive with a hammer (axe, etc.).
Is that correct?
Philbert
deye223
6:22 AM
Is that correct?
Philbert
Yes and they have a tendency as you drive one in the other one will bounce out cos there's more lift with a double taper wedge where is the single taper when you stack them the angles match better hard to explain bayleys used to sell single taper wedges years ago I don't know if they still.
And yes you are correct with the names of the triangles it's just that with all the heart medications I have to take and very high doses of beta blockers my memory recall definitely is not what it used to be unfortunately
Skeans1
1:22 PM
Of the 4 which is which? @Philbert
Skeans1
1:22 PM
You can stack A or C style wedges a little saw dust and technique goes a long ways we do it a lot falling timber.
K Mueller
12:22 PM
Alaska, USA
Philbert
Chainsaw Enthusiast
3:22 PM
East Dakota
(2) Yellow&Red ones (at left in bottom photo) are 'D' (slightly different tips than my sketch);
Orange (Husqvarna?) could have been 'B' or 'C' (and can be either with a little filing);
Long yellow one - cant' tell, but also could have been 'B' or 'C' .
This is part of the reason for my interest.
1) I hear these terms used so differently, and I was wondering if there were some agreed upon definitions to use when discussing wedges;
2) When restoring / renewing / salvaging wedges (as in referenced thread, below), I have the option to make them either 'B' or 'C', once the original tips are gone.
https://opeforum.com/threads/wedge-renewal.13185/
Philbert
Philbert
Chainsaw Enthusiast
3:22 PM
East Dakota
This is a related question, and whether it makes a difference if the wedges are used for felling or bucking.
In felling, the full wedge may be driven in to get lift, and multiple wedges might need to be stacked. As @deye223 points out, the points of some wedge designs align better when stacked, and the backs may align straighter for whacking.
When bucking, I am usually just concerned with keeping my saw from getting pinched (or getting it free when stuck). Maybe others drive their in full length when bucking large stuff (?).
It was interesting to find in some old Forest Service materials (same one @K Mueller referenced a few posts above) :
1) that bucking wedges for crosscut saws may need a finer tip, due to the thinner kerf made, compared to chainsaws;
2) old school 'bucking wedges' (look more like axe heads to me) were steel, and wide, and sometimes placed perpendicular to the cut, to keep the cut log from rolling / shearing when cut.
Philbert
Skeans1
1:22 PM
Philbert
The yellow and orange headed one are double taper double lifts, all the others are single taper single lifts. The orange ones are scotsco brand, the other the 15” is a double taper brand single taper single lift. All but the double taper double lift you can stack or even mix well stacking.
For the bevel on the front it’s personal preference I run all three and as you can tell a few have met the bar tip a time or two.
subhanseo
Bot
5:22 PM
Denmark
The Pitching Wedge (P), Gap/Approach Wedge (G/A), Sand Wedge (S), and Lob Wedge (L) are the primary wedge profiles; they vary in their loft angle and purpose. The Sand Wedge is used for bunker shots, the Lob Wedge is for high-arcing, short-range shots, the Gap Wedge connects the pitching and sand wedges, and the Pitching Wedge is for complete shots and longer chips. According to this PGAProfessional.com article, this Rock Bottom Golf article, and this Handmade Custom Clubs article, there are other variations and particular designs available, such as the "Hi-Toe" and various grinds (e.g., M, K, D, and S), which change the club's warrior names sole geometry.
10:22 PM
I call these "custom".
Never knew wedges were such a complex topic!
But more to the point, what oil and ratio does which wedge require? :rolleyes:
Junk Meister
3:22 PM
Nebraska
Until now No body mentioned the "Plumbers Crack WEDGE-E" OP had the options of A, B, C, &D. I submit the option of E.
This is the first time I have seen this thread. It appears Post # 13 revived this thread. If it is AI makes on curious what prompted the post.
59billy
3:22 PM
MS
For an aluminum wedge, any quality bar oil will do, provided the wedge has been polished to at least 400 grit.
