Velocity Stacks
jmester
9:31 AM
VIRGINIA
Does anyone here make velocity stacks? I am looking for one that will mount to a wj carb and fit a husky 394 air filter.
A.E.E.llc
Hello myself, its me again
9:31 AM
anywhere
What's the inside diameter of the 394 filter? Vstacks that Dave has are 2" o.d. that attach to wj.
jmester
9:31 AM
VIRGINIA
image.jpg Thinking of something like this. That has a 32mm od on the velocity stack. Shorter pipe and a steeper angle off the carb block. A thinner block would work better as well.
On a side note for you guys running velocity stacks do you have a problem with the switch shafts on the stihls popping out of there seat?
jmester
9:31 AM
VIRGINIA
Told you wrong a steeper angle off the carb block won't work I would have interference with the filter and filter base.
A.E.E.llc
9:31 AM
anywhere
What are you wanting to put this on? 2100 or 288 filter bases work well.
A.E.E.llc
9:31 AM
anywhere
Why not use just a velocity stack and a offset filter?
jmester
9:31 AM
VIRGINIA
Don't really want to run a filter that I have to oil. I know they have there merits just not something I want to mess with.
