- 10:14 PM
- Oct 12, 2021
- East, TN
So I put a new piston in a 2094, used an inner tube gasket between carb and intake boot, and also between muffler and jug. I use the mightyvac to 7-10 inches mercury, and it creeps down to about 5" in 40 seconds or so. Would that be considered good, or does it need to be solid at whatever vacuum pumped to. I tried it with compression release and plug. Just looking to see if I need to get this better. First rebuild for me.
Pressure test failing at carb to boot right next to bolt, not much tube there, going to try to plug boot without carb. I do want to test the boot too.
Thanks for any advice.
