Thank you John. No Sir I do not I drill from the back and grind them out but that is the hard way to go about it lol. I do plan on a mill in the future.Do you have a mill to bore for the studs?
I do have bigger bits but for the life of me I can't find them. Yes Sir I used my boaring bar on the first one I made.Do you have drill bits to where you could step drill it closer to your final dimensions, so you would only have to do a few clean up passes? Or hole saws and a boring bar?
Took me about 2 min to indicate it in I had already faced off each end. I use a grizzly 0602 lathe.How much time did you spend indicating it in? What kind of lathe are you using?
Sent from my SM-G935V using Tapatalk
What air filter do you run on them?Ok Men here is how I am building my stack
After I indicate it in well here are the pic if any body wants to add to this feel free to do so cause I am sure a lot of guys build these things and are way better at then I amView attachment 67549 View attachment 67550 View attachment 67551 View attachment 67552
