Unbalanced Blades
GBertolet
11:09 AM
PA
On a John Deere mower I recently repaired, I happened to touch up the blades, and noticed one of the two blades was way out of balance. Just grinding off a bit of extra metal on the heavy side would not fix it. I just let it go, as it was not the reason the mower was in the shop. Would drilling small holes on the heavy end, at a non critical area do. Or putting some weld, adding weight, on the light side work, to bring it back in balance? What do the experts do to balance a blade that is way off?
Moparmyway
Its just a saw
11:09 AM
In a meeting
I’d first want to know if you scraped off the stuck grass and dirt from the entire blade.
I usually find blades that much off balance took a hit from some hard or immovable object, and need to be replaced. If there is no impact, no visible reason for the outta balance issue, and a little more grinding of the edge on the heavy side doesn’t seem to work, I replace it, better to be safe, it’s a customer that expects the professional to keep the machine up to snuff
GBertolet
11:09 AM
PA
All the stuck grass was scraped off. It's not that terrible out of balance now, after much grinding, but still not as good as I would of liked. I am just curious to know what the professionals do when they run into this situation?
