GBertolet
On a John Deere mower I recently repaired, I happened to touch up the blades, and noticed one of the two blades was way out of balance. Just grinding off a bit of extra metal on the heavy side would not fix it. I just let it go, as it was not the reason the mower was in the shop. Would drilling small holes on the heavy end, at a non critical area do. Or putting some weld, adding weight, on the light side work, to bring it back in balance? What do the experts do to balance a blade that is way off?
