Robnjay
Active OPE Member
- 5:23 PM
- Sep 2, 2025
- Victoria TX
I’m trying to verify that I actually have a bad coil on this saw before I spring for the new part, here’s what I have done so far:
Replaced the solenoid with a new repair kit (white solenoid + orange filter)
Disconnected the 2 wire harness from the coil and measured both wires to ground - black is open until the lever is moved to the off (up) position, then shorted - red measures 36 ohms to ground. This is probably the resistance of the solenoid coil.
Measured the coil:
Primary is 1.87k ohms
Secondary is 2.4M ohms
Primary to secondary is 24.7k ohms
Zat 4 no spark…
Buy the part???
Measured the coil:
Zat 4 no spark…
Buy the part???
