fin460
- 6:44 PM
- Dec 29, 2015
- NW Missouri
I have an 026 that races at idle and won't tune out. It was a complete rebuild, split, new bearings seals. I haven't replaced the rubber parts, but have a impulse line and fuel line, filter on order.
It is passing multiple pressure and vac tests, cold and warm, and I've turned the crank over while testing.
Cylinder is always hot, after I make a couple short cuts, trying to get it to tune.
I plug my mittyvac into the impulse line, and cap off the muffler and the end of intake boot.
I had a Chinese style wt194 and tried it in place of the original 194. saw acts the same.
When I hold the throttle down it will rev up slow sounding super rich then all of a sudden, something lets loose and it rapps out super lean super fast.
Any ideas, i'm anxious to try a new impulse line, but the old one passes pressure test.
