Trees you've cut
TheDarkLordChinChin
My name Borat, I like you
4:49 AM
Ireland
The last big trees on this job.
Nearly all of them had to be climbed to set a pull rope.
I just wedged this one though.
Perfection!
See the bit of rot in the middle. A lot of trees had butt rot on this site.
The corner tree, it was particularly hairy. Rotten in the centre again.
A little persuasion, Couldn't be bothered climbing this one.
Hinerman
10:49 PM
NE OK
On and on it goes.
1 more day should see us out.
Another high stump, everything is full of metal here
I purposefully put my hinge in the root flare on this one to help steer it away from a building. It worked.
Just another spruce. There's a bit if rot in some of them.
If it's not an oversized spruce full of metal it's a big dead ash.
Do you think this tree had metal in it? 😆
Where does all the metal come from?
Sloughfoot
8:49 PM
Norcal
Mostly fences.
But some trees had old buckets, horse shoes etc embedded in them.
I've seen worse.
Most interesting metal I've hit in a tree was what looked like a piece of a cast iron decorative hanger about a foot into an old 6' diameter Valley Oak.
TheDarkLordChinChin
4:49 AM
Ireland
Back to removing ash die back trees.
The first two pictures are of relatively healthy specimens but the customer wanted them removed as he's building a shed beside them.
When in doubt leave a big hinge.
The tree on the right is alive and healthy, the two on the left not so much.
This was 3/4 of the way up.
One of these trees was loose at the roots. After we felled it we could rock the stump back and forth an inch or two. I thought it felt wobblier than usual when I was climbing it to set a pull rope.
Hinerman
10:49 PM
NE OK
Why the big hinge?
TheDarkLordChinChin
4:49 AM
Ireland
We finished this job on Tuesday.
There was one leaning ash 9 feet away from medium voltage power lines with a transformer.
It was also extremely dead. Dry, crispy, crumbly outer branches. Smelly, off colour timber in the top half of the tree.
What's more, right underneath it was the septic tank.
Every piece had to be rigged down except the lightest branches.
I free falled one branch and it clipped the lines. Luckily it was so dead it broke on impact.
I didn't take any photos, 1 because what we were doing would have breached our insurance and 2, im a bit superstitious and thought if I took a before photo then surely something would go wrong.
Anyways, heres some photos of another job.
More ivy.
This ash was very healthy, it was a shame to remove it. Like I said before, either I do the job and get paid or someone else does.
Look at all the different colours in the timber, that doesn't happen in ash die back.
I bought one of these stihl high lift felling wedges. Fcuking broke it on the first tree. The timber insert broke. Oh well, guess I can make one.
They call me Mr. Kibbs
11:49 PM
Wandering the VA woods
Sloughfoot
8:49 PM
Norcal
TheDarkLordChinChin
4:49 AM
Ireland
Geez! Looks like you spend as much time with the ivy as you do with the wood, gotta be frustrating!
(edited for crappy spelling)
2 or 3 times as much, not even joking. Its a disaster when you have to leave the job tidy, like in someone's garden. The worst is when youre working on gravel and the bits get all mixed up into it.
Here though we'll just push it all back into the ditch with a tractor.
Its really fcuking dangerous because you can't see what youre cutting or where youre standing or anything. It also pinches the saw a lot and causes kick back. Its even worse trying climb it because no way will you ever get a rope up through it and back down and no flip line can flip through it. Spikes on and climb like Tarzan, tie in when you get to where youre going. If you tried to strip the ivy as youre going you'd be an hour climbing a normal size tree
Leprechaun or some other kind of fairy ever drop out of that Ivy when you're felling it?
Birds, dead branches, lots of water, dust, insects, dirt, snails, slugs, TV ariels etc etc
huskyhank
10:49 PM
Is there a reason the ivy does not get poisoned? Especially on the trees near buildings? Is it killing the trees?
