Trees you've cut
TheDarkLordChinChin
My name Borat, I like you
2:34 PM
Ireland
Today's cut site. Ran Yamaha up to buddies cabin to clear out Alaska birch with rotted tops. Will be about 40 trees total. One bore cut heavy leaner hung up in a gust of wind.
Rolled it off the stump with peavey, but could not to rotate it. Last option is to set up that ghastly Lewis winch. Half dozen yanks with the Yamaha, finally came down. Broke the pintle!
Few things cutting in dead of winter:
Super exhausting breathing heavy in these below zero temps and having to wear all these layers/heavy boots. But money still gotta be made.
U have to pack down snow on all yer escape routes by foot or snowshoe.
Humboldt cuts are a no-go. Butt end of log burries in the snow. Then jams/compresses into the packed snow. Next day, sets up like concrete.
Conventional cut is better: crown slaps the snow, butt end of log stays above the snow.
Most cold weather bar oil won't pour from a jug. I thin with atf fluid. The red color is nice, show up in the low light that oiler ain't froze up.
Almost all rubber av saws are brutal to run in below zero temps. One surgery so far on my left hand. Dead of winter I'm starting to reach for spring AV saws.
Informative, thanks.
TheDarkLordChinChin
2:34 PM
Ireland
cus_deluxe
terms of service violator
9:34 AM
Michigan
TheDarkLordChinChin
2:34 PM
Ireland
Another mess.
These Southern beech trees pulled a wall up, broke telephone wires and snapped a telephone pole
The same man had about 10 spruce and pine trees blow down as well. I cut the fully fallen ones off at the butt, however there's still a few big hagers to get down.
He has a big ceder beside the house he wants topping in case the same wind comes again.
The old 3 o clock cut as its known. Gives you the best possible chance of getting your saw out of the tree before it gets pinched.
TheDarkLordChinChin
2:34 PM
Ireland
Another mess.
Went back to him today to top a big western red ceder beside his house.
It wasn't a nice tree to top.
It had lots of little stems growing up out if the oldest lower branches
A bit of a mess, a lot of throwing branches out and them getting stuck.
20241212_101525.jpg20241212_143230.jpg20241212_143241.jpgIMG-20241212-WA0001.jpg20241212_160627.jpg
The big tree hat you can see behind the house in the first and last photos is not small. I can't figure pout what it is.
It's definitely not a spruce and I don't think it's a Douglas fir. It's certainly not a noble or silver fir or any kind of pine.
Maybe it's a true ceder or a hemlock? We don't have many of those here.
I have to go back to him to cut more trees so I'll get a closer look then.
TheDarkLordChinChin
2:34 PM
Ireland
Haven't posted in a while.
Non stop storm damage work since december 7th.
This pine had fallen into a multi stemmed alder. I felled the two in one.
Thanks to the hard frost we were able to bring the tractor in and draw all the timber out. This field is very wet, it lies right beside a river. There was ankle deep water under half an inch of ice where an old shore must have run at some point.
TheDarkLordChinChin
2:34 PM
Ireland
2 of us spent 3 days cutting a road into a forestry.
The landowner rang me on Sunday saying he needed this road cut asap because his application was going to run out on February 1st.
No forestry contractors would come to cut such a small area.
The first road was 20 meters long by 15 meters wide. Well, really the road is 5.5 meters wide but total width to be cut is 15 meters to allow timber to be stacked along the road.
The second road was 60 meters by 15 meters with a 30 meter spur running off to the right.
No trees bigger than 2 foot diameter. A slow job but good fun.
Here's the west of ireland in one picture: a digger, a tractor, a forest, a horse and a bunch of auld people stood around talking sh1te 🤣🤣
TheDarkLordChinChin
2:34 PM
Ireland
Sounds nice, Cept the weather
The weather was ideal. Cool and overcast. The first day was still, bur there was a very slight breeze on the second two days.
The trees we were felling were all tall and skinny, maybe 10-20 inches diameter and 80 feet tall. Even a small bit of wind played hell with trees sitting back, even forward leaners that weren't heavy enough.
