traded a stihl ms 290 for stihl 026
jake wells
no longer here
4:37 PM
ky
Your 290 will outcut it in its current state. Hope you're not disappointed.
Like Joe said, it's a US made 026.
All you need to do is open the muffler, add a wt194 and metal air filter, and advance the timing a bit and that saw will be a different animal.
now if im looking at the flywheel in front of me would i remove key material from the left side of the key or right?
jake wells
no longer here
4:37 PM
ky
how much key should i remove and i don't own a micrometer.
jake wells
no longer here
4:37 PM
ky
harbor fraught is 40 miles away so when i get some time i will go get one.
jake wells
no longer here
4:37 PM
ky
compression is 160 according to my gauge so the saw seems to be healthy.
RI Chevy
5:37 PM
earth
If you have a spark plug gapper, you may be able to use that.
jake wells
no longer here
4:37 PM
ky
the way this looks i can take a single cut file and do two swipes and be done.
jake wells
no longer here
4:37 PM
ky
well that makes it easier i can file it while on the crank.
Cut4fun
Redneck Chainsaw Repair
5:37 PM
Ohio
Then again I would take my poulan over the 026. ;)
New to me saw. Took on trade.
Backtroller
4:37 PM
Land of Badgers
Took .020 the key, big muffler mod with an extra port with 1/8" stainless mesh, took a nylon airfilter, totally hogged it out and put stainless 100 or 150 micron filter (can't remember) over on both sides . This one had the fixed H it was replaced with a W194.
It is a totally different saw now. I always liked running it but now it is much better. However, with my ported 421 and 5100s I don't use this one too much. When I get this ported that may change. image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
Rob Stafari
5:37 PM
Cincinnasti
It is a totally different saw now. I always liked running it but now it is much better. However, with my ported 421 and 5100s I don't use this one too much. When I get this ported that may change. View attachment 32260 View attachment 32257 View attachment 32258 View attachment 32259 View attachment 32256
Might I ask what you adhered your stainless mesh to filter body with?
Windthrown
GFY Certified!
2:37 PM
The Cascades
The 026 is the far better saw. I do not know anyone that would take a 290 for one. I have owed a lot of both types (310s mostly, but an 029 and a couple of 290s). I still have a pair of 026 saws. You cannot 'port' a clammy 290 much, whereas you can port the holy crap out of an 026 in 12 different ways. They will absolutely scream even with mild porting. Then put a large mount bar low profile/Picco B&C on it, and you will spank a low revving, vibration prone and bulky 290.
As others have said here, that is a later model 026 made in VA Beach with a carbide TH, plastic starter cover, larger AF and obviously fixed jet carb. If you port it in any way, you HAVE to put a tuneable Walbro 22 or 194 on it. O/w you will run it lean and burn it up in a hurry.
Now with that all said, I am going out to use my 026/260 hybrid saw to dice up a few pines that I dropped here the other day. Light and nimble, and a lot of fun to use.
