SOLD Timberline Sharpener
Magic_Man
Oh Yea !
9:45 PM
SE Ohio
I have a timberline sharpener for sale. Used it maybe a dozen times at best. It will put a razor sharp edge on a cutter. I just decided to go back to learning how to hand file. Comes with a 7/32 burr for standard 3/8” chain and a 13/64” burr for Stihl 3/8” chain. New this would cost you $145, I’m asking $100 for it all.
Wolverine
dilligaf
9:45 PM
I’ve had one for several years. These are not the fastest method but like mentioned, they make an absolutely razor sharp, almost stropped edge. Every cutter is the exact same length and angle when finished. I still use it for family and friends who use round.
GLWS.
beaglebriar
The Peanut Gallery
9:45 PM
Warren Center, PA
GLWS.
I chuck the carbide bits up in a little 12v drill. Makes it much faster but it's hard on the aluminum inserts. Gonna try to sleeve a set with steel (either carbon or stainless).
Wolverine
dilligaf
9:45 PM
I've already wore through one set of those guides, so I oil regularly and I make sure to not pull the cutter out much. Only as far as needed so it doesn't carry any slivers/grit into the guide and accelerate wear. The drill method would be awesome IMO if the carbide was long enough to not carry that debris into the guide. Kinda sucks they are made of such a soft material. Your way would really speed the process up.
Magic_Man
Oh Yea !
9:45 PM
SE Ohio
Bump, make me a reasonable offer someone.
9:45 PM
i have one also but dont use it but on the 2 chains i did do i oiled them
it just sits in tool box
