- 1:17 PM
- Dec 3, 2015
- Banner Springs Tennessee
Remember that it will also provide a lower pressure negative signal when the port is open.
There it is. Yeppers.
Hang around, I'm gonna try one in a MC101m/c someday.I've been a bit curious about full circle cranks. They have been used
in the karting industry for years. I even bought a Mac 101 with a full
circle and it was made just the way your doing yours. I understand it
is filling the crank case more so when the piston is on the down stroke
there is actually more pressure to charge the combustion area. But is it
that much of a difference. Much more power? Or is it going to let the
engine spin to higher rpm's with less drag around the crank.
Lee
Man.....185 is a lot of intake, I kinda figured they would need more but wow!The saw this crank go's to is a 5000+ with 44mm jug. It has been a perpetual project of mine, but has taught me more about porting than most every other saw put together. Right now it has an intake block fitted, and running on a bored out WJ from an 066. It has 185 degrees of intake, 165 of exhaust, 20 blowdown.
I'm giddy with excitement.
You might say you're working on a full circle crank of your own?It's mine and I'll play with it when I want.![]()
Multiple plug welds and then you'd have to turn down the outside of the ring afterwards. I agreeI would think that even a tig weld would tend to warp a .025 ring...
