PissRev
#1 Husky 525LS
#2 Stihl FS94R
The Husky is still fairly new but I can't get over the power to weight ratio of this trimmer. Instant throttle response and revs like crazy but very easy to throttle the trigger around delicate items. A simple cat bypass muffler mod brought this trimmer to life.
The Stihl is an all around great well balanced trimmer but falls short of the Husky in power and throttle response. The choke system is the best I've ever seen on a trimmer but the Ecospeed throttle set wheel is a gimmick that I have no need for.
Both trimmers will crank in 2 to 3 pulls when cold and 1 pull thereafter when warm. Both have fully adjustable carbs if you have the Stihl hex and Husky spline screwdrivers. Both trimmers are a pleasure to operate and feel very close in weight. Both trimmers have very low vibration transmitted to the hands while operating them. The Stihl was nearly $60 more expensive than the Husky.
If I had to just choose one it would be the 525 with a Speed Feed 375 head. You guys can keep your heavy 4 stroke trimmers.
#2 Stihl FS94R
