Philbert
Chainsaw Enthusiast
- 3:56 PM
- Jan 30, 2016
- East Dakota
A while back, I was given the opportunity to try the Tecomec Chain Repair Master, combined spinner / breaker. This tool is unique, due to it's horizontal alignment, and dual function: it is not just a spinner welded to a breaker, but both functions are integrated into the same tool. It seemed like a compact alternative to having separate tools, especially for field work.
As received, it is a bit larger than expected (the main body is approximately 8 inches long. Mine did not have the handle shown in the photo above), and included many parts; there are separate breaker anvils for each pitch of chain, along with 2 spinning anvil sets, and a couple of hex wrenches to install and remove the anvils from the tool body. I made a mock up of an organizer out of styrofoam, and clearly labeled everything to keep then straight (the stamped numbers on some parts were hard to read). I mounted the tool to a wood base, so that I could clamp it to different work locations; added some initial padding to the handle (eventually gluing on a plastic, golf ball-sized knob at the end); replaced the hex screw on the clear guard with a wing nut, to make this easier; and a few other fussy things to make it easier to use.
I also found the correct thread bolt to hold everything in place when removing the spinner handle for transport or storage, and a cheap wrench to keep with the set for this purpose.
It is a well made tool, but not as convenient as having a conventional spinner / breaker set. Alignment of the breaker anvils is important. Applying pressure horizontally takes more muscle force than pulling down, where you can use your body weight. Keeping track of all of the small parts can be a challenge (conventional breakers have a single anvil that will work with multiple pitch chains). And change over from breaker to spinner to form loops takes more time than having separate tools set up, unless, perhaps, you are working in a batch mode.
Overall, I am confident that I can break and spin a variety of chains with the Chain Repair Master. The modifications described make it significantly easier to use. It could be a good option for a workshop with limited space, for compact storage, and for portable use.
I am more familiar with a conventional spinner and breaker set, and feel that I have more control when centering the chain rivets, using the stand-alone, vertical breaker press. The conventional breaker also allows the use of an adjustable anvil for universal fit, even on worn tie straps. Given the choice, especially with the near identical price, I would choose the conventional, 2-piece spinner and breaker set for most situations.
Philbert
Philbert
