Jimmy in NC
- 3:33 AM
- Dec 23, 2015
- North Carolina
Working on a 576xp. Saw is pretty high hours and acted like an air leak. Flywheel side up and it accelerates. Rotate back to normal and it almost always dies.
Passes pressure and vac check fine with OEM testing flanges.
Did a flywheel side seal anyways... bearing is fine in there. No change.
Popped the top end and evidence of being very hot on the flywheel side. Looks like lite scoring hours ago through some lines in the jug... piston looks fine.
Since I had a set it got new OEM rings. No change.
I do notice quite a bit of spit back through the strato ports. Piston also shows signs of rocking with wear below the intake and exhaust; machine marks elsewhere on the piston.
Could the piston just be worn out? Saws runs fine with good power other than it won't idle and tip over. Will run fine off idle.
Swapped carbs off another 576xp and still has an issue rolling side to side.. but now seems to die with a low rpm flywheel up. Two junk carbs? Original carb pressure tests fine.
