Stihl workshop manuals
AVB
12:28 AM
Pluto
Needing service manual for MS271. Has limiter caps that I'm unfamiliar with that needs to come off some I can clean the carb.
Already have IPL.
AVB
12:28 AM
Pluto
Thank you very much. I get to the saw today and see if I need the new puller or if one my Echo cap puller will work.
Mike C.
1:28 AM
New Hampshire
That is the manual for the FS111 . The FS110 uses the 4180 manual from 2007 which is attached. Added the 2018 service setting to the 2021 conversation. Have a look at page 18 for initial carb setting and rpm
Hi Ray,
You've got me straightened out,now.I don't know what made me believe manual 4180 wasn't the right one.Getting goofy in my old age,I guess.
Thank you for the additional service information and your time,sir.
Ianm
OPE Member
8:28 AM
England
Does any one have an IPL and workshop manual related to an early 044 with 10mm wrist pin
Thanks in advance
Ian
AVB
12:28 AM
Pluto
Needing a replacement SM for the STIHL Series 4144 Components FC, FS, KM manual have that is unreadable due file damage.
Jayo999
Active OPE Member
6:28 AM
Ireland
Lookin for workshop manual and ipl for ms362c please
SparkTest
New OPE Member
1:28 AM
NC
I'm looking for the workshop manual and IPL for Stihl FS70 if anyone has copies. Thanks!
AVB
12:28 AM
Pluto
Looking for HS82 manuals.
WI_Hedgehog
12:28 AM
Milwaukee, Wisconsin, U.S.A.
UPDATE: All needed documents have been SENT by @ray benson (thank you!):
I just bought a "slightly new" STIHL 009L and could use the IPL (already downloaded the service manual). In theory it should be in great shape, but I'll do Pressure, Leakdown, and Compression tests given its actual age. (If I have the manual and IPL the saw won't need seals, right???)
Also a STIHL MS 400 Service Manual and IPL. (bought two saws in one day... :qmiedo:)
The 400 is on the way from STIHL and should be here this week, so same "it won't break if..." reasoning applies?
