Hugo
Active OPE Member
- 8:18 PM
- May 2, 2018
- Chile Temuco
Check your inboxAnyone have service and IPL on BR 800 ,X ,X-C
Check your inboxDid a search and can not locate 500i service manual?
Thanks, Keith
Check your inboxNeed Stihl 400C ipl
Check your inboxAnyone have an IPL and service manual for a BR340. Thanks
Check your inbox
Mr. Ray is the man!
New model, I have nothing on it. Please send me copies if you find them.Anyone have IPL and service manual for an HSA60?
Check your inbox.IPL for a 462-CM, Thanks
Sent them to you Aug. 19, 2021 in a conversation, do I need to resend it?Hi guys,
Anyone have the service info for a Stihl FS-111 line trimmer/brushcutter? Thank you.
That is the manual for the FS111 . The FS110 uses the 4180 manual from 2007 which is attached. Added the 2018 service setting to the 2021 conversation. Have a look at page 18 for initial carb setting and rpmHi Ray,
The manual I have is "Stihl series 4180 powerhead,Service Manual 2016-11. Is this correct for the FS-111?For some reason,I thought this was for the FS-110.Or is it applicable to both models?
I want to try adjusting the carb on this FS-111.But strangely,the manual only covers how to adjust the idle speed and idle mixture.The high-speed mixture adjusting procedure is never mentioned nor what maximum engine RPM should be.
Thanks.Mike.
