STIHL trimmer dies when letting go of the trigger
Merkava_4
12:30 PM
Clovis, California
FS 91 R 4-Mix.
Run perfectly fine and runs strong. Let go of the trigger and it dies. Starts right back up on the first pull and idles fine.
Put the trimmer back to work and it dies when letting go of the trigger. Rinse and repeat. I'm at a total loss as to why.
Coupe
8:30 AM
New Zealand
Long as it is running well under power it sounds to me that you may
have to tweak the idling screw up a bit till it keeps running when you
let the trigger go. If that does not fix it then it may be your jets.
If you have not played with them before be careful you don't get
it to lean or you may cook your motor.
Merkava_4
12:30 PM
Clovis, California
Sounds like it could be too rich and floods out during deceleration. Has anyone ever adjusted the carburetor?
That's exactly what's happening. But if I lean out the high side so that it doesn't die on deceleration, then it's not rich enough to get to full throttle under load. I've been running the high side rich so that I can go max speed at full throttle in wet tall grass. It might be time for a new carburetor.
EFSM
2:30 PM
Extreme southern IL
Sounds like a rich low side. I should have specified. The 4 mix at idle need set just rich of peak lean; they shouldn’t be as rich at idle as a standard 2 stroke.
lehman live edge slab
Live Action
2:30 PM
Mn
Don’t a lot of the 4-mix have accelerator pumps on the carbs also? Could that be messing up some?
EFSM
2:30 PM
Extreme southern IL
All of them do, at least the OEM carbs. If those o-rings are bad they can cause just about any problem you can think of. Normally it shows up as #1 pulling air through the primer, #2 the idle leaning out after running a few seconds (air is pulled around the bad o-ring and back into the metering chamber), and #3 sluggish acceleration.
Merkava_4
12:30 PM
Clovis, California
I swapped out the carburetor. The new one runs perfect at the bench setting. 1-1/4 out on the L and 3-1/2 out on the H.
I'm surprised it runs so well at the bench setting but I'll take it.
Thanks for all your help EFSM. You're one smart cookie. :thumbsup:
hacskaroly
2100 Fanclub Member
12:30 PM
Northern Idaho, Ehh
That is great to hear, I wonder what was up with the old carb, I guess partially clogged somewhere? Did you go OEM or AM on the carb?
Merkava_4
12:30 PM
Clovis, California
I actually put the original carburetor back on. I had taken it off because I thought it would not stay in adjustment. Come to find out, it wasn't the carburetor's fault. It was the fuel tank vent. There's no way to keep the mixture settings where you want them if the fuel tank keeps changing pressure with the fuel level.
Coupe
8:30 AM
New Zealand
Yes always some silly little thing like that will cause a problem.
Like a lot of people will bring a saw to me and say I have tried everything to
new plug checked carby but forgot to check if they have spark or not.
First thing I do is pull the stop switch wire of the coil and bang away
we go.
I dust ask them do you want me to get a new on/off switch or will you get
it. As i have said to them checking for spark is the first thing you should do.
No spark no fire up.
