Stihl plastic tank repair??
Cooper264
10:17 PM
Southern WV
Does anyone know anyone who knows someone that can repair a stihl plastic tank for a reasonable price.
I've got a 066 redlight that ide like to have the tank fixed on. It leaks at the seams
10:17 PM
Your gonna want to make sure there are zero gas fumes left before you even touch it with the soldering iron. Let the tank sit for a day or two with the gas cap off.
Gizzard
10:17 PM
KY
Another option could be Red-Kote tank sealer. I’ve repaired quite a few metal and plastic fuel & oil tanks with it.
Cooper264
10:17 PM
Southern WV
can i just pop the two havles apart, clean em up, put em together, and then just melt the crap out of them?
10:17 PM
Just solder it where it’s leaking (they usually leak on the bottom from being scuffed on the ground over time). It’ll be a toss up wether it works or not... sometimes it does sometimes not.
furb
10:17 PM
Womelsdorf
I don’t think you would have any luck separating the halves and getting it back together. That’s a hard to find tank in nice condition. Hit it with the soldering iron. If that doesn’t work try something like q bond and try to pull vacuum with a mityvac. If that doesn’t work do what Gizzard says. You don’t have to go crazy with a soldering iron. Just run it down the seam.
Creaky limb tree care
3:17 AM
Wales UK
Super glue (cyonoacrylate) works wonders on fuel tank seams, I have repaired a good few, with zero comebacks!
Cooper264
10:17 PM
Southern WV
The guy I bought the saw from (originally I was just working on it for him) tried to repair it with some sort of acrylic. I think the gas ate it or something because it's still leaking. I may just try cleaning the edges up with a drimel and go around it with a solder iron
