- 10:27 AM
- Dec 4, 2015
- In a meeting
It automatically tunes itself. There is no choke or cold start lever.Do you have to reset the saw when adding the bark box, or does it automatically retune ? ..
Could be from all the effort put into trying to start it after it broke. That would fog a bottom end real good with oil.Here’s where I’m at with my observations of this saw and the mix that it’s been used with:
1. surprisingly, I see oil in the bottom end and on the piston.
Take the dogs off the bucking saws and teach them to make chains that cut on their own. When they master that, put the dogs back on.
I’m not sure that I’m where you’re at right now Kev, the bottom end looks real good. The oil I’m seeing is probably from trying to start it, so even if I wipe off all of the oil, this saw has been running cool enough to keep the bottom end looking nice. Either Homer Simpson ran the last tank or two with a dull chain, or the switch to the different oil is causing the carbon scoring. I’ve seen my 500i banging on the limiter while cutting a stump, went through a bunch of rocks and water, Dominator at 25:1 and she still looks brand new, no matter how dull the chain or operatorTake the dogs off the bucking saws and teach them to make chains that cut on their own. When they master that, put the dogs back on.
The first initial smear may have had some thing to do with the switch from orange to gray bottle oil, but most of that is from just not enough lubricant or fuel to cool it down from running dull chains it looks like to me. I’d still be mixing the red armor at 40 to 1 just to be safe
Banging the limiter may have helped. The dummies running it dull may have leaned so hard as to heavily load the engine.I’ve seen my 500i banging on the limiter while cutting a stump, went through a bunch of rocks and water,
Point is that there aren’t any signs of detonation and that this saw can run 87 as equipped from the factoryMy personal preference would be to use premium gas in the saws, especially if it gets a compression boost. It makes me feel safer.
Dominator actually works really well in a saw. I’ve been running it at 32:1 now for a couple years and there’s very little carbon on the piston and none in the exhaust portSo from what I’ve read, Dominator oil is only recommended in high performance racing engines that produce high amounts of heat. The additives won’t fully burn and actually will leave carbon deposits.
Interceptor oil is recommended… at least if your into spending $20 a pint on oil mix.
Chainsaws produce high amounts of heat.So from what I’ve read, Dominator oil is only recommended in high performance racing engines that produce high amounts of heat. The additives won’t fully burn and actually will leave carbon deposits.
