TheDarkLordChinChin
My name Borat, I like you
- 4:18 AM
- Feb 2, 2020
- Ireland
What is the filing system? File the opposite way to normal? I know that's how you do it with one of those vallorbe double bevel files.I have it on an MS500i / 32" bar. I dropped and bucked a few 3' diameter pines with it. It seemed to do pretty well. Tried the file afterwards. Not sure I like the filing system.
Not too terribly pricey, so I purchased two. I have been experimenting recreating the hook on C83 chain with this file and so far it‘s been working great. A 5/32“ round file first and then using the Hexa file to do the hook for a partial Hexa I guess.View attachment 436788
Yeah so I tried it for a few tanks before I threw my chain and destroyed the drive links.
It cuts fast enough but is grabby and aggressive.
It doesn't peel out long chips, it makes thick, hard pieces of dust. At least in ash it did. I think this is due to the angled profile of the side plate, as in the sharp "hexa" angle breaks the chips before they peel out fully. At least that was my takeaway from using it.
I sharpened it once and used it again and it cut just fine. Again, in ash.
I have not tried it in anything different yet or filed the rakers at all.
What brand of DB file you use, Vallorbe is my choice, and seems to last quite well,I have now worn out 2 of the Hexa files. They appear to fail in the same way as double bevel files, the point where the sides meet goes dull and they become impossible to use.
I was able to file through 2 chains per file so if you can get the Hexa in a kit, it's ok value. The kit with 2 chains and a file is sold here for the same price as 2 RS loops.
You think a triangle file could replicate half the hexa profile? Be interesting to see how a smoothly transitioned half round/half hexa tooth would cut.I bet there are off the shelf files that could replicate hexa.
I like the cut feel of the Pferd's and that I got a box of them cheap off Amazon. Both them and the Vallorbe's are really good. File life with them improved a lot when I swapped to filing inside out.What brand of DB file you use, Vallorbe is my choice, and seems to last quite well,
I'm not really into this idea. If you are willing to pay the price for a 3 square file and are willing to use it, then there is a much better, more efficient, profile you can create with it.You think a triangle file could replicate half the hexa profile? Be interesting to see how a smoothly transitioned half round/half hexa tooth would cut.
Long story short - if you have a square file, square file it.
Hexas big advantage is that it's extremely easy to sharpen because you don't have to control the file height. Other than that it's cuts and holds its edge the same as a regular round filed full chisel sharpened at 25/60/60
Durability testing is just about impossible so all we can really give is our opinion on this stuff. It could be better, I just don't know.I agree, forgot the attempted dummy proofing of the hexa file. I do feel it’s a smidge more durable but I have only tested one loop a little.
