- 7:25 AM
- Feb 5, 2016
- grafton wv
speak english thats a work chain for meYou run that as round, you will get protested and disqualified.
Chain looks fairly new. Sometimes there is hardly enough room for the file between the tooth and the raker. Practice.
I think you are right, certain combos get you basically to the same result. You can really feather the edge with the guide and a light touch, so they're going to be sharp and cut just fine regardless of minor differences in set up.wouldnt the 10 and 25 give you a tooth close to the 0 and 30 i am not sure which way angle up or down ?
@dall I'm calling ya out for the world to see. Work chain to work chain race. You and I. You bring that chain to Randy's Gtg.speak english thats a work chain for me
Bring that one to. I'll bring my files, just incase you want me to touch them up for ya.
Honestly, I just eyeball it when I use my granberg. KISSHow do you guys get the increments, like the file 1/10, or as mentioned 20% above the top plate, so dialed in? Do you recommend the use of a caliper?
If you have a clip on or screw on file guide you could use it as an example of how high the file should rideHow do you guys get the increments, like the file 1/10, or as mentioned 20% above the top plate, so dialed in? Do you recommend the use of a caliper?
I'm in the Wilkes-Barre/ Scranton area.What part of NEPA are you in?
