Stihl E031 / D025 question
~Yellow Streak~
Active OPE Member
8:19 AM
Foothills Of The Smokies - Knoxville, TN
Just wondered if anybody has tried mounting a Oregon E031 mount bar to a D025 mount saw? (with spacers of course) Are the adjuster holes spaced the same and do the oil holes line up?
Found a good deal on a 16" E031 mount bar. I have a Stihl 028 super I'm hoping to get fixed up if not too much $$$.
It's a nice old Windsor Speed Tip
Maintenance Chief
8:19 AM
South Carolina
I know theres a fellow who makes an adapter for that so it must be feasible.
I've got a 32 D025 for my 088 so a little reverse engineering should work.
SOS Ridgerider
Muffler Modded Member
8:19 AM
Central CT
The oiler hole on the E031 bars sit quite a bit higher than on a D025 bar. I’ve modded an E031 bar to work with D009 with an adapter, and it’s definitely doable, just takes a little work. The best 14mm mount bar to run on a D025 or D009 mount saw is the D033. That’s the old large Dolmar mount. The oiler holes line up, and all you need is an adapter on the bar studs.
~Yellow Streak~
Active OPE Member
8:19 AM
Why in the world did Windsor make a 16" bar to go on a E031 mount saw? Everyone would be snickerin if you put this on an 088. You'd probably have 14" of usable bar with a spike :meparto:
Maybe the mount was incorporated on some small saws?
Lightning Performance
8:19 AM
East of Philly
Maybe for old hardwoods. The Aussies use short bars for post ripping.
@SOS Ridgerider
Do they make a D033 in 16"?
SOS Ridgerider
8:19 AM
Central CT
@SOS Ridgerider
I haven’t seen them in shorter than 20”, but that doesn’t mean they don’t exist, or have existed. @166 may be able to clear it up. He knows the older stuff much better than me.
~Yellow Streak~
Active OPE Member
8:19 AM
Yeah, i guess if you wanted your saw lighter, you could put a 16 on it. You could still take down a 22" tree working side to side. A lot of unnecessary stress on the nose though IMO. I'll probably drill the rivets out of the tip and mount the carcass for "off saw" .050 filing.
So... I paid $24.28 for the 3/8 nose. They're getting harder to find anyway.
Albeit, I'll have to find rivets.
8:19 AM
East of Philly
Steel rod works just fine
