WANTED Stihl 441 HO oil pump
stevegodseyjr
11:34 AM
Midwest
Looking for 441 HO oil pump. The one I have is junk and needs replacing. Let me know
Steve
chipper1
11:34 AM
Grand Rapids Mi
Any idea what you want for them? Is this a common issue for the 441?
I had a drive gear/worm gear(the plastic screw part) go out on one before but the pump was fine, that was on a newer 441cm. I've had a good number of them and that's the only one that went bad, I've never had one go out on the 046/460/461 I've owned so I'm not sure how common it is.
Morningman
Active OPE Member
8:34 AM
If it's the same as 044 or ms440 I have what you need
stevegodseyjr
11:34 AM
Midwest
I have read that the 441, 046 and 460 are all the same. I am not for sure though.
ManiacalMark
11:34 AM
PA
Cheaper to just modify the pump and save some time.
11:34 AM
I don't think it is, iirc those are the same as the 361.
99% sure it’s the same pump for 361/046/461. Different bolt pattern than an 044/440-they won’t fit.
Not sure on the 441, but if it’s the same as above, you can either buy the 460 HO shaft and adjustment pin, but the entire HO pump, or Modify a regular pump to pump more.
@huskihl has a good thread here on a DIY mod.
Steve, did you open your pump and see what failed? They are pretty robust units that rarely have issues. Is your worm gear ok? Is it engaging the clutch drum? Oil supply and feed lines clear of debris?
Let’s see a pic?
stevegodseyjr
11:34 AM
Midwest
I will see if I have time to pull it apart soon and get a few pictures of it.
I will also try to find that DIY modification thread also.
Thanks!
Morningman
Active OPE Member
8:34 AM
I have some 361 oilers and one for a 441 if you need 1
Morningman
Active OPE Member
8:34 AM
Oiler
chipper1
11:34 AM
Grand Rapids Mi
Let’s see a pic?
Very good possibility I was wrong, it's happened before.
Morningman
Active OPE Member
8:34 AM
Sure no stripped gears
Bomar
8:34 AM
oregon
Any of you guys have a good 441 gastank/handle
