stevegodseyjr
- 3:16 PM
- Dec 28, 2018
- Midwest
Looking for 441 HO oil pump. The one I have is junk and needs replacing. Let me know
Steve
Steve
Any idea what you want for them? Is this a common issue for the 441?From my memory, 441 uses the same pump, as 046, 460, 461.
Should not be that hard to find one.
I am sure I have 1 or 2....
I had a drive gear/worm gear(the plastic screw part) go out on one before but the pump was fine, that was on a newer 441cm. I've had a good number of them and that's the only one that went bad, I've never had one go out on the 046/460/461 I've owned so I'm not sure how common it is.Any idea what you want for them? Is this a common issue for the 441?
I don't think it is, iirc those are the same as the 361.If it's the same as 044 or ms440 I have what you need
99% sure it’s the same pump for 361/046/461. Different bolt pattern than an 044/440-they won’t fit.I don't think it is, iirc those are the same as the 361.
Got a closeup of that gear? Is it stripped?Oiler
Very good possibility I was wrong, it's happened before.99% sure it’s the same pump for 361/046/461. Different bolt pattern than an 044/440-they won’t fit.
Not sure on the 441, but if it’s the same as above, you can either buy the 460 HO shaft and adjustment pin, but the entire HO pump, or Modify a regular pump to pump more.
@huskihl has a good thread here on a DIY mod.
Steve, did you open your pump and see what failed? They are pretty robust units that rarely have issues. Is your worm gear ok? Is it engaging the clutch drum? Oil supply and feed lines clear of debris?
Let’s see a pic?
