Stihl 084 Tilly carb elbow
Clarkc9743
4:15 PM
Mt Vernon, IL
I have a pretty rough 084 that does run great but one of the many small things I found wrong was the plastic elbow on the carb sucking air instead of fuel. Does anyone know of a replacement for the tillotson carb preferably steel or brass. I do not want to pull it out of the carb unless I can find a replacement because I have managed to cram a peice of fuel line on it and it works as it but I want to do it right. I found these on eBay but I can not confirm if they will fit the carb.
https://www.ebay.com/itm/OEM-STIHL-...p2349624.m46890.l6249&mkrid=711-127632-2357-0
Thompsonader
5:15 PM
Lagrangeville
Iv been using the copper looking tube off other carburetors to replace those plastic elbows
Clarkc9743
4:15 PM
Mt Vernon, IL
That is what I ended up doing I wasn't sure if it would work and didn't want to damage the carb but eventually just gave up and did it anyway and it works find.
foresterntree
2:15 PM
California
Not sure if they’ll work, but I’ve been using these https://ebay.us/m/Sc4ioj to replace the plastic elbows that crack. I usually use a drill bit just a little larger than the inside diameter of the metal piece that goes into the carb, and it pulls out pretty easily once it’s weakened.
