Stihl 084 muffler repair
NPKenny
10:11 AM
Lehi, AZ
What would be the preferred method to repair the top bolt tabs this 084 muffler? I presume it was originally welded nuts in these locations and it currently has through bolts with shouldered nuts. The front cover is in excellent shape.
I just picked this saw up and it is pretty solid although there is certainly wear.
FFCD8540-795A-4C9B-B619-7E5B9AF57756.jpeg CCCF073B-7A63-4641-BEE2-9A9101DFA74D.jpeg 12AA53CD-A402-497A-93AC-F5D6C1068877.jpeg D0F45D3B-6D47-4A84-8ECA-74839CDFBB05.jpeg
10/80
3:11 AM
MIG, TIG , OXY, any competent welder should be able to repair your muffler using the welding processes mentioned.
NPKenny
10:11 AM
Lehi, AZ
I would weld a nut of the size you want to a washer then just weld the washer to the back of the muffler it will be stronger and be a good repair.
This is a tenable suggestion for me. The base material where the nuts pulled out is very thin and drawn out. The washer would reach good metal all the way around.
NPKenny
10:11 AM
Lehi, AZ
I’d back that, float entire area with SiBr, clean up and then tack the nuts on. Tig
I find SiBr the easiest to fill large voids with.
This looks like silicone bronze would be an excellent fit for this. Do you traditionally braze it or mig?
Bill G
12:11 PM
What model muffler did you start with, i imagine that you modified an available one
The thread is over 2 years old and I do not think Phil is active much anymore. I believe he cast it. He made steel mufflers and cast sprocket covers for the 090G also that were very good. I have a few.
