Stihl 064 Tribute Build
Evansaw
11:29 AM
Greece
The coil you have is the CDIC coil (1122 400 1303). As long as it has spark, you're in good shape (it is a rev-limited coil though).
This will be a great build! I did something similar recently for my uncle who passed.
Thanks alot for info.
DND 9000
10:29 AM
Germany
Brake has serial number 1122 792 9100
That break handle (1122 792 9100) was used in the past. It was replaced by 1122 790 9103 (064, 064 W) from serial no. 1 44 673 876 on. That change was near the end of 1999. This break handle is mounted in a rubber bushing at the fan side and secured with an IS M5 x 40 x 25 spline screw.
Evansaw
11:29 AM
Greece
Thanks
BonScott46
10:29 AM
Sweden
Did these have limited coils originally or is that a later replacement?
jacob j.
Only the weird
1:29 AM
Coastal Oregon
The 064 had the rev-limited CDIC set-up at the same time when the "Red-Light" 066 was in the line-up. The problem was, the metal-flywheel 066s
were breaking cranks on the flywheel stub shaft due to the very heavy 066 metal flywheel and people hitting the chain brake routinely while the
saw was still spinning. The inertia from the heavy flywheel over time would damage the crank. The rev-limited set-up was designed to reduce that.
The 064 didn't have the problem as much due to the lighter flywheel.
The big problems with the CDIC coils are a high rate of failure and the ones that keep going suffer from "brown out," where they continue to
function but the rev-limit keeps getting lower and lower. I've seen a couple that would only allow the engine to max out at around 10.5k.
BonScott46
10:29 AM
Sweden
Thanks JJ, great info.
Evansaw
11:29 AM
Greece
So today got a few hours and went on to clean...
talk to me about GOLD DIGGERS!
Never seen before such dirt and it's already cleaned before picsAC3EB253-43E5-4560-88D3-F94B212472EE.jpeg67BBD3CA-800F-4A12-8F2E-0D75E759F899.jpeg
Evansaw
11:29 AM
Greece
Evansaw
11:29 AM
Greece
755E017D-B5CD-4095-89A4-E892DA2CAD38.jpeg C2FD080A-B03E-4CD2-A1C9-3DAF2A8452B9.jpeg 9EB16A01-DC8B-4A13-8F53-72BF429924E5.jpeg Crank and rod are good though no play755E017D-B5CD-4095-89A4-E892DA2CAD38.jpeg
Should I change the rod bearings? What a mess...
Evansaw
11:29 AM
Greece
Meanwhile in Gotham City an hour later...
i know 99% of you guys would just throw it away and get new. But as said i ll have to try
there are a few scars laying around
Are they important I don't think so
34EA4EB4-AFAF-4CA2-90A4-491AC7B9B1A8.jpeg FF17FB60-A6DF-4057-856D-E06106FEF900.jpeg 37728798-59C7-41D2-B07E-D84E6B4F49F7.jpeg
Evansaw
11:29 AM
Greece
Now this was the worst part so far
I know it is abused but is it possible after the paint that it could still hang on? How much the paint would affect it? Positive or Negative?
That's a cross road right here.
DBFCAF87-BA5C-4339-9A4E-AFAC0FE225EE.jpeg 0E1E0A2D-70DE-4EC6-869D-B49502B08631.jpeg 94A47FE9-E168-447E-97A3-F4AF23673A12.jpeg 9642D5A3-B305-4D2F-B585-1869A1C3167B.jpeg
View attachment 215091 View attachment 215092 View attachment 215093
Evansaw
11:29 AM
Greece
E5C81C1A-85CC-4054-86EA-2E878CE49B18.jpeg BE847890-DD3F-4CED-9582-AD3157B0A1D0.jpeg F57A0B2F-CBF2-4871-BFA9-0742C80883AA.jpeg 1120A27E-E335-4025-905C-5D9ED6422F68.jpeg B411E824-8B9B-46D4-9E72-BC12978771F5.jpeg Keep looking keep thinking and looking again...
Can i save this case? I don't want to just put a new one without trying.
Would the preparation sanding damage it more before painting?
