tapritchett
Can you replace the 50mm P&C with a 52mm version with a 10mm wrist pin? Asking for a friend.
I don’t believe there is a 52mm piston available with the 10mm wrist pinCan you replace the 50mm P&C with a 52mm version with a 10mm wrist pin? Asking for a friend.
I haven’t. I only use oem pistons in 10mm 044. Typically the saws I’m working on belong to someone else and with the supposed pin boss problems with the meteor 10mm pistons it just isn’t worth it for me to gamble.meteor in my 10mm
ever weigh oe vs those?
Eggsellent call!I haven’t. I only use oem pistons in 10mm 044. Typically the saws I’m working on belong to someone else and with the supposed pin boss problems with the meteor 10mm pistons it just isn’t worth it for me to gamble.
meteor in my 10mm
